ADS random IFH-0009 error
  • Hmcre
  • 12. November 2022 um 08:06
  • Hmcre
    Hi, my name is Lorenzo and this is my problem:
    When I connect the ADS interface to my BMW E36 '97 I often get the error IFH-0009. With INPA and DISv44 I am able to enter the selected modules almost without problems, at the latest on the third attempt. The real problem I have with NCS EXPERT, it's a drama because I can read and download the modules 1 time out of 20 attempts. I can't understand why sometimes everything is perfect and sometimes it takes so many attempts.
    My specs:
    Laptop: Dell D830 with rs232
    OS: Windows XP SP3 x86
    Interface: Do-It-Auto ADS
    Ediabas: 6.4.3
    Thank you in advance
  • Zur hilfreichsten Antwort springen
    • 12. November 2022 um 21:24
    which modus you use it? obd or ads?
  • Hmcre
    • 13. November 2022 um 07:11
    Hi, only ADS mode
    This is my COM1 port config:
    Bit per second: 9600
    Data bits: 8
    Parity: None
    Stop bits: 1
    Flow control: Xon/Xoff (i've tried "none" but same result)
    Fifo enabled
    • 13. November 2022 um 11:38
    you must try it on OBD mode too.
    because from the year of construction 1996, many modules respond to OBD
  • Hmcre
    • 16. November 2022 um 16:39
    Hi, I followed your advice. I put the interface into OBD mode by doing all the various resets in ediabas.ini and obd.ini. .
    The OBD mode interface in the modules it can read is just perfect, such as GM4 and EWS.
    In NCS, vehicle identification via EWS is lightning fast.
    Of course, in OBD mode, it can't and won't get into non-OBD modules like the Kombi.
    My question is this: how can I get the same connection stability in ADS mode?
    Thank you
    • 16. November 2022 um 18:03
    ADS = KW-71 protocol is a bidirectional data transfer you can read more here Description Protocol KW-71
    ADS the stability is just as good as with obd, but the transmission rates prevent a fast data flow
    You can use BMW DIS or so to test which one is better, you can find here solution
    Dear Value Customers! This is the last chance to own the proprietary version of ISTA Standalone 4.37.40
    ISTA Standalone will no longer be released and will be discontinued, unfortunately. As owners of the program, instead of the Standalone version we will offer…
    www.diagnose-software.com
  • Hmcre
    • 18. November 2022 um 16:44
    • Hilfreichste Antwort
    Hi, I tried a modification on ediabas.ini, basically I changed this values:
    TimeoutConnect = 9000 (2000)
    TimeoutReceive = 9000 (2000)
    TimeoutFunction = 30000 (10000)
    It would seem that now everything works perfectly in ADS mode, I can enter the various modules on the first attempt without receiving any errors.
    Thank you for all the help you have given me.
    Edit.
    I entered these values for testing, are there any default values for the ADS interface?
    • 18. November 2022 um 17:01
    I'm happy that everything works according to your wishes.
    No
  • brajo456 28. Juni 2024 um 20:18
    Hat einen Beitrag als hilfreichste Antwort ausgewählt.
  • ifh-0009
