Make ADS interface work with PCMCIA-Serial adapters
    • Tutorial:
  • 8. Februar 2012 um 22:54
    PROBLEM: The ADS diagnostic interface for BMW cars is infamous for requiring a "real" serial port and not working with PCMCIA and USB adapters. Serial ports are quite rare on modern laptops.
    ANALYSIS: The ADS interface uses a driver that bypasses Windows settings and targets the default hardware address of COM1 directly. Virtual serial ports have a different hardware address (or in case of USB an entirely different access mechanism) - therefore they don't work.
    SOLUTION: A tool that patches the driver. Here you go: download AdsPort tool (requires .NET framework 2.0)
    The tool will patch your ADS driver to target a different COM port address - this means that it can be used with standard PCMCIA adapters, but not USB adapters.
    To see the hardware address of your virtual COM port:
    - open the Device Manager window
    - right-click on your virtual COM port device
    - select Properties
    - go to the Resources tab (if there is none, the device probably doesn't have a hardware address and you are out of luck)
    - write down the first number from the I/O range (something like "03F8")
    Please let me know if the tool works for you in the comments. I have only tested it on a couple of PCMCIA cards, a single notebook and INPA ...
    EDIT:
    user reports:
    - works with INPA + E36 '93, E38 '99, E38 '00
    - works with TOOL32 + E39 IKE
